twiget
I've been wondering, does a big block have any inherent advantages over a small block? These days it is very doable to build a 350 with 400hp & 400lb/ft, what used to be big block territory. Heck, if you want to spend enough $$$, a supercharged V-6 can do 300hp plus.
So, given a small block 350 and a big block 454, both putting out around 400hp & 400lb/ft, what are the pro's and con's of one engine over the other?
