I figured I would post this up here in the Garage for max visibility. If its better suited somewhere else feel free to flag someone to move it.
So here's the deal:
This is my ham radio transciever. It does everything I want, ham bands from 1.5 MHz through 450 MHz, receive on CB/GMRS/FRS, etc.
I like to move it between my desk, car, truck, and the field.
Four M4 screws secure it in place.
What I want to do is build a mounting bracket with an 'L' shape (rotated 90 degrees) so it can just slide and drop into place. The bracket is no big deal.
I'm having trouble looking for an ideal fastener. I could just use these same M4 screws. But I would really like some posts sticking out of the side to make insertion into the bracket easy. Then there would be some type of tension mechanism (1/4 or 1/2 turn) to secure the thing in place.
Thoughts/suggestions?
I could swing down to the local Fastenall and see if they have any ideas. Figured I would run this past the brain trust first in case someone knows just the thing I'm looking for
So here's the deal:
Yeah those would work.
Also one of its mounting locations is a car trunk. I don't need the adhesive failing in summer temperatures.
