COCHEV
so i purchaced my burb with a 454 and a healthy cam in it of unknown size. i only get about 10 inches vac out of it and i have the idle turned up a bit so it wont die in gear (th400). still when, getting off the gas or simply puttsing around in parking lots and what not, i doesn't like to idle well and consequently i loose my vac assist for my brakes or it dies and or both. not fun with a big burb. it also has a edlepuke 750 in it and i put the lightest springs in there (which really helped) still, not too stoked about the crappy idle and the truck is serving full time work truck duty now. oh, and i know that i do have the 049 heads and 1.72 roller rockers. otherwise the rest is a mystery
soooo, i also have purchased a hydroboost set up for it. which might help the braking issues, but not the stalling and poor idle. should i go for like a 500-1000 overstall converter? how are those for daily driving? or should i do a cam swap to something i know would work at a lower rpm range and stock stall speed...
at all other rpms it runs like a beast and has tons of power
thanks in advance,
jason
thanks in advance, jason
