smog pump conversion?
Smokinthehippies
3/4 ton status
Millard, NE
gotta question for you gents.
the smog pump on an 81, is there anyway to turn that into a little air compressor to fill up a tank? i know my yota buddy said there was a way to do that on his yota so it got me thinkin.
any one with any links or insight, much appreciated. :popcorn:
Don't let your buddy work on your truck..........
As far as I know, all those pumps are low pressure volume pumps that use vanes instead of pistons to move the air.
Might make a good personal fan, but if it can produce over about 5 pounds pressure I would be surprised.
At least you weren't asking to use it as a supercharger.....
Martin
Think we need to change your user name to Smokinsomegrass. :haha:
Martin
I've seen them used on go-kart engines as a blower....whether it increases HP enough to offset the amount the pump robs from the engine to make the boost is debateable though!...:rolleyes:..
I think a York compressor is the best option for onboard air...seen a few guys adapt an old 2 cylinder cast iron compressor from a 110V unit to their engines too,but they had to rig up a v-belt idler pulley so it they can remove the belt when its not needed...they also re-used the tank and some of the plumbing like the safety pressure releif valve..
fyi orignal poster your in cali you need that to pass smog dont you ? ? ?
or is this a trailer only off road buggy build ?
as said not going to work for your needs . bust get a bracket kit and drop on a york and have a REAL compressor that moves 10cfm of air . :thumb:
Lol that's a new one. I have heard smokintheherpes before
Smog is only every two years. I just need to pass it now and ill be gone before it comes back around
