Plank or right now should be called
Good lordie does it smoke right now. The blazer originally had the PCV hooked up under the throttle body. It burning the smallest amount of oil but always felt PCV related.
With Plank, I tried putting it in the air cleaner, for some negative vacuum but less aggressive. That caused it to smoke heavily from the breather.
I moved it back to under the TB and good grief Charlie Brown does it smoke.
I didn't notice anything wrong with cylinder walls while looking past the crank. Heads were not taken off. Intake and valve covers were.
I'm a little deflated. Happy to hear it start, my goodness it's a bit loud in the car. Guess that's I6 -> V8 for ya.
Cause video
It's definitely more smokey that what comes across on video. Fumigating the backyard.
Cause video
It's definitely more smokey that what comes across on video. Fumigating the backyard.Attachments
