91 Jimmy. Replaced my dash lights with some LED's. Had some cheap-o amazon ones in there, bought a few Sylvania 168's and liked how bright they were so I decided to get some for my I/P. I swapped them out and wasn't getting any light. Checked the 5 amp instrument light fuse and it was blown. Replaced it, still no light. Started adjusting the dimmer switch and it started to smoke and it popped. I thought that maybe the lights were trying to draw too much power (even though they're rated for less wattage than a typical 168 incandescent). Put the cheap amazon ones back in that had previously worked up until now, same problem: no light and as I turn the dimmer switch towards the brighter end, it gets to a point where it pops and smokes. Dimmer switch is about a month old, but I still had my old one (worked fine, but the wiper on the switch was worn and would cause the lights to flicker sometimes). Plugged that one in, same problem. I've attached a video of what happens (the I/P isn't plugged in because I was trying to eliminate that as an issue). Headlights, taillights and all other lights work fine, just no instrument panel lights.
From the wiring manual, it looks like the LT GREEN wire on the switch controls the high setting on the dimmer switch. Is that where I should check for a short? There are two other terminals (10 and 12) that don't show what wires feed them. Does the dimmer switch get power from one of the other 4 terminals on the plug? I feel like if there was a short on that section I wouldn't have headlights, taillights etc. Let me know what you guys think
