Sneak peak for the Ck5 brotherhood.
cybrfire
1 ton status
Iowa
Try to put some numbers with these tomorrow if I get a chance to sit down and do some figuring.
How big of a pin for the clevis hooks will fit in those holes on the top pic?
I'm retarded. What are the things in the bottom pic?
Couple questions.
1. The top pic looks like they are designed to slide into the receiver hitch to make it a good tow point?
2. Can you make a longer version because my pin location is further back than normal? I see it says 1 inch pin for the clevis, but what is the diameter of the hole for the reciever pin? I would imagine you could make that whatever I desired.
3. Can I get a custom one done and delivered prior to blazer bash?
Thanks Kert as always outstanding products
Couple questions.
Yep, slide in the reciever for a tow point.
Can make a longer version. Won't be plated. Hole diameters are a smidge over .625" and 1". As far as what we can do with the diameter of the holes, yes, they can be changed to some degree. Obviously there is a limit to how big they can be.
I don't see much possibility in getting a custom one to you before Blazer bash.
Cost on the tow clevis is $52.00 plus a ride. Ship flat rate US mail for 9 sumpin.
Standard ones as pictured are ready to go. Easily in hand before BB until we run out.:eek1:
This piece is sold in pairs complete with studs and shim packs to align the heim slot.
$90.00 for the setup.
tow clevis point is up on the website now. Top of the misc. page.
$90 for a pair and they accept a heim and the stud goes into the steering ram? 3/4 - 16 stud?
Yep, they accept a 3/4" heim and 3/4 fine (can't remember the tpi off hand) stud. Studs ARE included at that price as well as shim packs for alignment.
3/4" -16 ftw
