Snow plow & 88 Blazer parts
crash1369
Tobyhanna, PA
Ok people here goes hate to say it but the blazer scene has not been good to me and I can’t take its punishment anymore :eek1::haha::(
anyway what that means my loss is your gain I've got all the parts of an 88 full size blazer, 4x4 auto plus all of the drive line for the 4spd and a almost new Fischer minute mount II plow for sale. The motor and automatic trans were rebuilt, the auto needs a new valve body I think, the sm465 has a brand new clutch and flywheel never used. The front has manual hubs and there is a locker in the rear. I will sell the whole thing for the right price otherwise make me a fair offer on the parts. everything works besides the already listed trans and the body except for the front end, the frame is fine. If you want the frame though obviously it will have to be the last part to go, depending on how much of the truck you want. like I said everything is negotiable make me a good offer and it’s yours. any questions just ask.
Chris
do you have any pics of the truck?
i guess i should get some, i don't have any yet though. the front end is perfect like new the rest of the body is worthless except the fiberglass part thats nice. it was a plow truck so pretty much everything has surface rust but nothing major. ill put some pics it wont be untill next weekend though sorry.
i believe it has a Detroit locker in it (i dint put it in though so im not sure could be a different brand) the axle is the stock 88 (10 bolt, maybe ill check) and which trans do you want?
Yes! you want just the case or the trans too? its got a brand new clutch and flywheel, i also have a 3/4 ton drive shaft for it if your interested.
the drive shaft i need is the gm one mine looks like a two piece real skinny in the middle of it. the problem with mine is when you hold it and wiggle it its loose right before the ujoint that goes to the front axle. i seen on lmc that there about 250 but cant afford that much now, do you know what i mean this is all new to me.
mine should be the gm one im pretty sure it was never changed. ill check it out tomorrow night and let you know.
ok here are some pics of the drive shaft as far as i can tell there nothing wrong with it.
ive also got some pics of the rims on there now, the tires are like brand new very little mileage on them the and rims are good.
all the other pics are here for thoes that may not have seen them.
http://s77.photobucket.com/albums/j59/crash1369/blazer/
edit: i forgot one
ok thats the one like mine. did you check too see if it had any play in the middle of it where the grease fitting at the end of that cap like mine you can take it and move it back and forth has little play in it. also how much send to 12561 thanks.
