Not for leaf springs or body mounts or anything that normal.
I have a bunch of bushings, I would need to get steel sleeves for them ( both outside and inside) some of them are kind of small.
I think using the small ones would be fine on the transmission, and transfer case crossmembers, because they aren't controlling as much rotational torque as the engines bushings would be. Also easier to mount.
I don't think they would wear out overly fast either because the forces being exerted on them.
I see the logic in just using the biggest bushing, more space to flex before wear becomes an issue, overall probably more vibration dampening. But I don't think it would be a big deal at all to use these small ones.
So the question is why big bushings ( builder bushing size) for transmission and transfer case mounting?
Talk me out of the small bushings and I will wait till I can get some bigger ones but I think the small ones will be fine
