So after a 63" spring under and 14 bolt SF 6 lug swap in the rear,
BlaZeus
The Real Mateo
Sheridan, WY
On my 81 k5 with stock front suspension and a 350 motor and auto trans, I get a really bad death wobble around 30-40 mph. And then it goes away around 55-60. But usually i slow down and it lasts until I come to a complete stop. What could be the problem? I have redone the rear suspension 3-4 times and it hasn't gone away. I am now turning to the front end and wondering if something up front might be causing a problem? The spring under is causing the truck to sit really low in the rear and I adjusted rear axle pinion angle accordingly. Any help is greatly appreciated. Thanks.
You prolly have some wacky alignment issues up front if the rear is sitting super low..... Id bet castor angle is causing it.
Yeah I took it in and they couldn't even get readings off it Cuz the tires and truck are too big.... But I looked up front and the front leaf bushings are completely toast. So that might be it. I'm swapping in a 3 link this weekend so hopefully that solves it but we'll see. Thanks!
