Quackaddict
Plan on starting the 3/4 ton swap on Monday. No I am not getting rid of it and while I have the time. I will be doing a 3/4 ton swap and 6 in lift....to include all the fluids, brake lines, zero rate etc.
I will be doing this by myself the directions for the lift say 5-8 hours.......hahahahaha no really. Gonna be a bear but I plan on taking my time and I have all the right tools and I know what I am doing.
I figure 2 full days sounds right?
) breaks. Its not hard if everything bolts up, I have air tools but generally only use my hand tools unless im feeling lazy.
Most things were done with hand tools but air came in handy disassembling.
more like quadruples the time needed. I had to cut all of my leaf springs then cut through the spring eyes to get at spring bolts in order to cut them. 5 out of 8 of the bolts had to be cut. Also burn bushing doesn't smell that great
. For my 4" lift it took me about 3 weeks to do. It could have saved me a week had one of the factory spring hanger not rusted out to the point that I couldn't bolt a spring to it. I burnt out my angle grinder cutting the thing out and went through at least 7 cutting wheels on it. And it could have saved me a day had I not needed to drop the gas tank because it was in the way and too close to all the sparks from the grinder.
