well just the tool of choice you know...just would hate to get it all done and find out there is a easier,cheaper,faster way...i know you can use the sazall but im just not to kosher with it
dont take this the wrong way but the way rubber reacts to stuff like you want to use you might be the next darwin award winner.
sawzall / router / chainsaw / other high speed moving blade tools = bad things.
exactly. a tire groover is designed to do what you want to do with it. the blades are numbered, don't get anything bigger then a #8 blade. I have ones wider then that and they cut terribly. its simply to much rubber to push through and the blade cools off and dulls. its easier to make more passes with a smaller blade.
my tires hook up fine with a lot less grooving then you are talking about. just carve through the centers of each tread block and freshen up all the edges. no need to remove half of a tread block. its the edges that do the grabbing, not the large lack of tread. there is enough meat in a swamper carcass that you can groove the stock openings deeper. I have started doing it to mine.
I have seen comp guys use a grinder to touch up there groove job before a run. remember you are after edges, lots of them.
im sure groving works just fine but im shooting for something diffrent..i have 200 bucks in theese 42 so its not like im cutting up a brand new set...i wanna see how this lug method works
you got to admit it thought they do look badassYou never know until you try. Might just find, If you run low enough pressure....You might nor even need to groove that heavy.
and whats this water/antifreeze mix stuff? thats only a cheep way of loading a tire for weight for traction on like farm/industrial tires. NOT street friendly at all at speed.
I have seen several comp rigs running water/sand in the front tires, and I think its pretty stupid. Lots of broken parts, no balance, and a pain in the a$$.
also what about water/anitfreezr mix in the front tires?/anyone running this??i see it helpfull and hurtfull at the same time
I know quite a few people that have tried it......and they dont think it makes your rig work any better. I guess you never know until you try it yourself.People run water in the tires to lower the COG.
Sure, its a little harder on the drivetrain just like any added weight. A few hundred pounds of water is just as hard on the drivetrain as a few hundred pounds of sheetmetal etc.
The two cool things about adding water to the tires are that they add weight at the lowest part of the rig and don't add any more inertia to the tire/wheel (i.e. if the tire is spinning and suddenly comes to a stop, the water will still flow inside the tire and won't be forced to a sudden stop like the wheel/tire. This won't hurt shafts like a heavier wheel and tire will).
Here are a couple buggies with water in their tires:
That's keeping a low COG
I don't run water in my tires but I don't think its a bad idea at all for a trail only rig.
i think i might have to and see how it goesI know quite a few people that have tried it......and they dont think it makes your rig work any better. I guess you never know until you try it yourself.
