Which transmission are you going to use? Need to make sure you have the correct flexplate combination to match your trans.
Right now I have an NV4500 using an Advance Adapters bellhousing. For now I was planning on just keeping that.
Replace the rear main seal and the gasket on the piece the rear main goes in.
Even if it's not leaking now? Just in case?
Remove and cap the cooler line port on the oil pan. Cap and bolts easily sourced from the dealer.
What gauges are you going to use? You'll need the adapters for the sending units.
another thing I need to look into...
You'll likely want slotted motor mount plates as the engine may need to be moved forward from the small block position in order to clear the firewall. I had to move mine forward almost two inches.
I looked through your build thread a bit and I saw that you made your own mounts. I recall hearing good things about Dirty Dingo mounts. anyone heard anything negative?
I can program your computer as can Eagle Mark and there is a couple more but I can't think who right now.
Thats good to know, thanks!
Voodoo injection in Boise. He does harnesses and has done enough motors he has a very good handle on things
coolio, I'll look into that. I'm actually going to be heading up to Boise early next month so that might work out.
Oil pan, intake, lifter valley, valve cover gaskets
So basically replace all the gaskets while I have it out? If it wasn't leaking I was planning on leaving it alone. Bad idea?
I hadn't heard anything bad about the water pumps.
I'll check into it though.
You got a link for CCP engine mounts?
As far as the AC stuff goes, I don't have AC now, so I was thinking of eliminating it. Although, if I can make it work it would be a nice addition. Certainly low on the priority list though.
