I adjust mine and it works great until a fender hits a tree or a rock. I gave up. 3 hits with a fist and it opens.
I think I just cleaned, lubed, and adjusted IIRC.
Mine closes very easily, its just the opening that is a pain in the butt.
SUCCESS!!! Took the latch off, soaked it in degreaser and scrubbed it with a brush. Then oiled it up.
Tugged on the hood spring a bit to make it a bit longer.
Hood pops up like a champ now! This is a small victory that feels really big.
Thanks all!
The thing is, the latch felt like it moved very freely, but I'm thinking that I was messing with it when it wasn't under spring pressure. Probably just had some crud in it that bound it up when it was under load.
Either way, I'm way happy.
Think about this....I'd wager it is 95% of everyone's problem and repair (not quick fix).
Many in this thread have stated their latch moves freely. The cable is good. Lubed massively. But it didn't fix anything. Because it's not the problem.
You can fix it right now, in 5 seconds, with a pair of slip channel pliers, period.
No one looked at the pin IN the hood - The one which the hook/latch latches to. For the most part, the pin develops a flat spot on the top side which you can not see from all the years of rubbing from the hook.
Open your hood and spin the hood pin 180 (and see the flat spot), and restore the round edge to the top of the pin.
The hook/latch hangs on the flat spot, and the hood spring retains enough tension to stop it from releasing. When you tap the hood with your fist it simply pushes the hood down just far enough to let the hook release from the flat spot.
With the round edge back in place, the hook has nowhere to hang up - And releases like it should.
Check it out - I hope this fixes the problem for everyone.
Troy B
Ft Hood, TX
