I've discussed this before on here but I'm actually almost to the "start buying things" stage.
My '89 Blazer V1500/K5/whatever.
6.2L diesel, tow package, 202,000 miles and change.
Was used to tow a lot at some point and the high mileage has definitely taken a toll on the springs.
The rear sits with a lean down to the passenger side. It's about an inch lower than the driver's side.
The truck sorta wallows and sways a lot more than I like. Granted it's a 40 year old suspension design and 20 year old parts but sometimes it's as bad as a Wrangler with coils and no sway bar.
Lastly...this spring I met a local with a 60,000 mile '89 Jimmy V1500 and on his stock suspension and 33's his truck looked like it was lifted compared to mine.
So Shady is selling me his '88 half ton Burb's stock springs. Nothing fancy but at 100,000 miles they have half the mileage mine do and his Burb seems to have lead a cream puff life until the guy before him got it...and promptly killed the engine. He says they sat evenly and the rear was actually higher, as it should be.
Which leads me with the rest of my suspension thoughts:
-Thinking poly bushings all around.
-Some good nitrogen monotube shocks. Maybe Bilstein HD's but at least some Rough Country Nitro 9000's.
-Shackles? With greasable bushings?
-U-bolt flip in the rear...work with a stock suspension?
-What else?
What would you upgrade/replace on the stock suspension if you were rebuilding it?
No, I'm not going to lift it at this point. It does everything I want as it sits now while fitting under a standard slightly lower than 7' garage door jam. Not going to put bigger tires on and not going to wheel it hard so I have no use for a lift kit. No, a lift kit is NOT cheaper than a suspension rebuild. Price it out.
MAY do 1" Zero Rates or EZ Inch AAL's after I put the springs in and see how it sits...MAY.
-What else?
Nevermind.
