I have a mechanism which I am attempting to lubricate, and I'm unsure of how thick a grease to use.
(It's part of an autochanger mechanism for a DVD burner, so as to do automated backups of many, many discs, fwiw.)
The gizmo in question is bearing driven and slides horizontally on a ~3/8" steel rod. It binds, just a bit, and this throws the whole works into a fit. The bearings are inside, but look like maybe 1/16-1/8" diameter ball bearings, to give you an idea of the scale of the thing (i.e. it's fricken tiny in comparison to the trucks!
I've had the best luck with wheel bearing grease, i.e. thick stuff, though it's still not quite right. I also tried white lithium, which if anything seemed a bit worse, and silicone spray didn't do squat.
I guess, rather than specifics, I'm looking for general guidance as to when to use what type of lube (no jokes!
) ... given bearing and/or clearance sizes of (x), use a lubricant like
Or any suggestions of what's next thickest after wheel bearing grease ... if anything. After that it seems like sticky mud might be best =))
Thanks!
(And no, I can't go to the manufacturer for advise ... seeing as I am he and he is an idiot, i.e. this is home-built.)
-- A
)I've had the best luck with wheel bearing grease, i.e. thick stuff, though it's still not quite right. I also tried white lithium, which if anything seemed a bit worse, and silicone spray didn't do squat.
) ... given bearing and/or clearance sizes of (x), use a lubricant like Or any suggestions of what's next thickest after wheel bearing grease ... if anything. After that it seems like sticky mud might be best =))
Thanks!
-- A
