Who has the best combo of known fitting LS swap mounts and new engine cross member which will work well with cross-over high steer. I currently have like 5-5.5" lift I want to be sure it will work with as low as 3" of lift and a stock 5.3L truck pan.
Currently I am running a drop pitman arm, and drop drag link. I would love to switch to a straight drag link if possible. I get a small amount of rub between drivers side of the engine cross member and my drag link. I never feel it contact though. I am ready to upgrade my engine and trans mounts. I want a combo that has known good fitment with the stock 700r4 (4l60e) trans cross member.
Is DIY4X the way to go? Use their poly engine mount kit with an OEM style poly trans mount in the stock trans cross member?
