Yukon Jack
Ran some ladders over to a buddy yesterday in my 69 K20 and saw an unusual amount of oil under my leaky Rockwell T221 transfer case. I'm guessing I got low on gear oil (been awhile since I topped it off).
Looks like it took out the rear bearings on the input shaft. Anyone have experience with this that can let me know what I'm in for repairing this. Looks like NAPA has rear input shaft bearings for about $32.
I do have an NP205 that I can swap in - I actually sold it to a the buddy who I was taking the ladders to and he says I can keep the NP205 if I need it.
I also have a spare Rockwell T221 - I have never used it so I don't know anything about it, other thahn the fact that it spins in all gear selections just fine.
I assume the transfer case has to come out if I decide to try to just replace the input shaft's rear bearing. Can't imagine that I could get lucky enough to be able to replace it installed in the vehicle. Also, I can only assume there are metal pieces from the bearing in the transfer case that need to be removed.
Probably want to do what is the simplest route. I know the NP205 would require making a new hole in the hump and with carpet I would have to either do a patch or replace the carpet. The carpet is very new and I doubt a patch would look very good.
From web researching today I see the NP205's crossmember sits 1.5 inches back compared to the Rockwell's crossmember. I also see that the NP205's crossmember is 1" deeper (the transfer case sits 1" lower). I also see that some driveshaft length adjustments may well be necessary.
One of my goals in the near future is to get rid of some of my truck's body lift. I had to increase the body lift to clear the bbc when I swapped it in. One option that I have been considering is moving the engine forward and also dropping the engine down a touch. Moving the engine forward 1.5" to 2" probably gets me the necessary firewall clearance to get the body lift reduced down to 1-2".
So, I haven't put a tape measure to all of this, but maybe I could leave my transfer case crossmember where it is and put in the NP205 and move the engine forward - thereby killing two birds with one stone. The reduced body lift will probably allow me to avoid needing to drop my existing crossmember down 1", unless I need to do that to keep the engine sitting at a proper angle, and I guess I need to consider if that causes any driveshaft angle issues.
My other winter project that plays into this is I'm swapping a Dana 60 soon - that might require front driveshaft lenght adjustments too.
Lots of issues, feel free to chime in with thoughts and recommendations!
You're killing me!
