So there's this thing on the back of my intake...
Brake booster hose is 11/32" and special thickness to avoid being sucked shut and restricting vacuum to the booster--some had a charcoal canister in line to absorb fuel vapors in hopes of prolonging booster diaphram life too..
Most vacuum gauges have a 3/16" or 1/4" hose connection,but also come with a funnel shaped adapter fitting to allow it to be used on larger diameter hoses...the brake booster can be connected to the intake fitting thats in your pictures,it matters not where its connected, as long as its to manifold vacuum source,and the stock hookup is directly above that under the carb's throttle butterflies..no reason why a "T" cant be used and one side blocked off,just be sure to use a good method of blocking it off so the brake booster wont lose vacuum..
Running with a vacuum leak like that could burn a valve or cause pinging,if left that way too long.....at extreme higher altitudes the leaner mixture may actually make it seem to run better however,but re-jetting the carb and having no vacuum leaks is the way to go..
The way to use the gauge to set the carb & timing is to first set the timing to stock specs,then adjust the carb idle mixture screws to obtain the highest and steadiest needle readings on the gauge--some engines will show as much as 18 to 22 inches of vacuum when tuned properly,others with a hi performance camshaft wont show much over 15 or even less,and will be harder to get a steady reading from..
I have found the timing can often be advanced some by up to several degrees over the stock settings without the engine protesting by pinging under a load ,or cranking hard during hot starts..that will improve gas mileage and power to some degree..
You guys just keep on bringing the answers!
Ok, good news. I went to NAPA today and told them that I needed a 3/8 male NPT "T" fitting with 3/8 female NPT ports and they have to bring them down from another store, but I'll have them in a few hours. I'm going to use a 3/8 nipple fitting for one port to hook the brake booster up to and I'm going to throw a plug in the other side and only hook up the small nipple fitting when I need to hook the vac gauge up to alleviate the possibility of a cap coming off if I were to keep the smaller fitting on there. I'm going to use thread tape on everything to keep it from loosening up and to keep things from possibly leaking.
3/8 is about as close as I'm going to come to 11/32 correct?
I'm going to use the factory jets and rods and get my timing together.
I'm really looking forward to the hissing noise going away and a possible increase in power and a good idle.
It's going to be nice to relocate the brake booster hose from the carb to the intake too, don't have to keep unhooking that thing every time I pull my carb.
Thanks again for the great info, I'll definitely be referring back to this thread in a few weeks to get everything to where it needs to be.
Yes,the closest fittings with hose barbs will be a 3/8",they use 11/32 hose for an extra snug fit and you could use 3/8" hose as long as its rated for fuel and emission uses and has sufficient wall thickness not to collapse under the vacumm..not all fuel line meets those specs...the stock hose has fabric lining sandwiched between the layers of rubber to make it stiff enough not to suck shut..
The T fitting with a plug or pipe cap used to cork it off is a good idea...that way you wont have to worry about a rubber cap or hose blocked with a screw coming off ..
I used to have a vacuum gauge in my dash ,that I'd leave hooked up all the time in my old K5,it helps you keep an eye on the engine's state of tune,and you can use it to help increase gas mileage by driving in a manner that doesn't let the needle drop too low--the lower the vacuum,the wider open the throttle is,and the less mpg you'll get..
This is what I got from NAPA, I bought two of everything just in case something ends up getting stripped out, plus it's always nice to have a spare on hand.
Get fuel injection hose. It's got the fibers built into it already. It's like 5 bucks a foot, but a lot stronger than standard rubber line.
The hose I have on there now is fine, I just wanted to make sure I was getting the right size fitting for it.
