So what did I break?
jonathon
Washougal, WA
I was going through drive thru today at my favorite burrito place and I bumped into this concrete post that is about 1.5 feet tall and invisible.. no visible damage to my eye :crazy:
Get out on the street and I notice my steering wheel is now rotated about 45 degree's to the left :eek1: I'm at work so I can't check the alignment but I'm going to assume something got bent or messed up. Give me some ideas? I've got tomorrow off to figure this out.. hopefully it's not a major break.
Could've bent your tie rod, or maybe twisted your sector shaft. I'd start there.
I hope it wasn't the sector shaft, this is my daily driver..
ETA I hit it with my passenger tire
Same thing happened to my uncles truck last year. He's still driving it. I DO NOT suggest you do this but it's his wood truck and not a big deal. Not sure exactly what it is but i'm subscribing cause i'd like to know so maybe i can act smart and tell him what i think ;)
havin any troubles turning right??
Haven't tried yet.. I'll post back when I get home. Going to go play with it, on my way out the door from work.
Probably loose u-bolts
Think that would happen on the original suspension? I'll check them out.
I drove it home(25 miles or so) with no issues.. stops straight, drives straight, and no weird vibes. Going to check things out tomorrow when it's day light. It seems when the wheel is straight, the driver's side tire is straight and the passenger side is pointed out a bit.
I'd say a bent wheel maybe but it'd vibrate AND drive funny. Hmm
Odd situation here. No idea
If the tierod was bent, the tires would toe IN, not OUT. (Unless somehow its threads were magically loosened, which is not gonna happen.)
If the wheel was bent, it would flop in and out as it rotated.
Put it up on stands ... if the passenger tire always points out in front, then A Really Bad Thing happened. Balljoints could be shot ... but I'm thinking the spindle itself got bent, or the knuckle is thrashed.
Read up on the procedure for replacing balljoints, as your teardown will be exactly the same. If the tire is visibly out of alignment, then the spindle or knuckle or other broken or bent parts should be obvious.
I would HIGHLY recommend NOT driving on the thing until you've torn it down and looked at it... if the knuckle is cracked, even, it could completely disintegrate just going over a bump on the highway, and that is a bad, if not fatal, accident waiting to happen.
OTOH, the parts aren't hard to come by; like, uh, post in the wanted section here for whatever you find is thrashed, and any of us who've upgraded to crossover steering and flat-top knuckles prolly have the old stuff laying around you could have for cheap.
Anyway, at the very least get the wheel off and *closely* examine the truck ... if you're not familiar with the axle, take both front wheels off and compare the driver's side to the passenger. The brake rotors should be parallel to each other, i.e. the sides of the truck when the steering wheel is point straight ahead, etc etc.
EDIT: Though I think it less likely than a bent spindle, it could be a suspension issue, like loose u-bolts or (more likely) a broken spring leaf, or the axle got bounced back off the center pin of the spring pack. Same advice: take off both wheels and compare left side to right. Use a measuring tape if you need to ... if the center of the wheel on one side is materially farther from the front of the truck than the other ... bad ;)
-- A
Turned out the alignment was just dicked up bad...
I broke down and took it to a shop :( Never done that, ever. I just needed it back on the road ASAP because until July I don't have a back up car that's street legal(K5 runs great.. it's just not street legal!).
The place I took it to does good work and is honest.. they checked out the spindle, passenger side knuckle, and ball joints. It all looked good other than the alignment. I was kind of surprised about the ball joints... trucks got 105K on it, what's the life span of ball joints?
one of my trucks has 140K on the factory balljoints and my k5 has 269K on its originals. sounds crazy but everything is solid and i've had shops look at both a few times just to check. always ok.
Must be hard living and big tires that kills them..
