So what is your weekend wrenching to do list?
Big91RustyBucket
New Lenox IL, Area (Chi-town Suburb)
So what is your weekend to do list for the trucks.
Heres what I got.
Install Rear D Shaft (Need either new yoke or to drill a bolt out , that broke for the PO)
--- Hook up Exhaust (Check)
--- Splice in new starter Wire (Check)
--- Install Starter
--- Reinstall Steering Shaft ( Going to JY Tuesday for new one )
--- Install Plugs/Wires & Dizzy
--- Adjust Push-Rods
--- Make Trans Cooler Line
--- Connect all Wiring
--- Install Dust Sheild
--- Fill All Fluids
Hope to get her running this weekend. :D
Pull transfer case 203, get motor and trans ready to come out, loosen all bolts for a 3/4 ton swap. First time for all hope im not in over my head. I know the 203 is gonna be heavy but not sure of how much fluid is gonna come out between the trans and case. we will see only way to learn is to try then come and run to ck5 for help.
im trying to put my engine back together before i drop it in the frame rails any help would be appreciated on my thread.
I might go out and cut my front fenders to be like DavidB's. I like the look of the J-cut on the front.
I will loose my lower head light but I dont really use hi-beams anyhow:D .
Dik
Hmm my To Do list.
1) Put gasket/seal in my Warn Hub some how I dont have one, so Warn was nice enuff to send me a replacement.
2) Replace the bolt that I had to bust up to get my warn hub off. Hope Lowes/Home deblow has one, otherwise, its another call to Warn.
3) check fluids and tire pressure in Blazer.
4) Work on my newly acquired project. 1983 Honda Shadow VT 500, picked it up for about 400bux, got about 300 in it including title/registration and getting seat recovered. Ive got a coolant overflow leaking out issue. Was told that the system is small and really needs "burped" good to get air out, ive got rad. cap on order from Honda to see if its faulty cap...........
so anyways........here is snap shot of my new beast.
The pic is deceiving, it makes bike look better than what it really is. lol.
Nice bike, I've got an 86 500 shadow
And my plans are to bolt up the drivers rear spring hanger and take off the pass. side and bolt that up to (52" spring swap), then cut, drill, grind some shackles out of 3/8", bolt up my springs, drill tap ream whatever else the knuckle at my bodys shop (hopefully, if not ill send it in to wfo), bolt up my x over steering, bolt on my shocks/shock mounts, throw the tires back on and go wheelin' :D
well planned on welding in the new floors, but unfortunately the wife's uncle was being cleaning up his yard & I didn't want to impose. Sucks. Oh well, hopefully during the coming week we'll finish up & off she'll go to my buddy's shop for the 10 pt cage. woohoo.
Change out rear spring, move rear spring hangers, valve seals, x bracing in cage, look at making shock towers............ anything else I come accross before my Dusey trip next weekend, oh ya I have a 16 day weekend this week :D
Let's see..
Friday night - visit with in-laws
Saturday - Family reunion + drive to Detroit for Tigers game (spend parts money on eating in the stadium)
Sunday - church, wife invites friends over for dinner
Sunday night - post stuff on CK5.com and wish I got more done on the truck this weekend than 1 power window.
heres what i got for next week.
sat. go to 4x4 swap meet, and if time go to a junk yard and get a power steering pump for my grandpa's work van
sun. fix my drivers window in the k5, and take a look at the front hubs. and if i went to the junk yard, power steering pump for ford van
Blue85 said:
Let's see..
sounds similar to me :doah:
friday night - angels game
sat - got to wash the k5 and explorer, took 4 year old to swim class while watching the 14 month old (so the wife could do house work).
sun - church, family picnic in back yard, running errands with wife.
in order to work on my k5 i will have to take vacation day this friday :(. plan on changing out cap/rotor/wires, maybe plugs, fix a coolant leak on the block where the heater hose hooks up, hopefully install/weld in a cat converter to pass smog by the end of the month.
Next couple days off I have I plan to do the starter and work on the floorboards, seals, and weather stripping. Havn't figured out the exhaust yet :(
i have a list to do for the blazer, but was only able to work on the vette,
1976 vette,
fixed exhaust leak on right side sidepipe.
rotated the tires.
checked all fluids.
started changed master cylinder.
2007 huffy bike ( the one my stepson ran into car :eek1:)
fixed bent front wheel
adjusted brakes to work betta.
repaired bent seat.
tightened handlebars.
hopefully i will get some blazertime in next weekend.
