bigbadchev84
Ok got my 14bolt ff with 4.56s and a detroit, Turns out the brakes were trashed and looks like a spindle is messed up, Can I just speedysleeve this as a temp/permanent fix?
wow say good by to that spindle.![]()
Couldn't you just clean up the bearing surfaces and see if some new bearing cones will press over it ok? As long as they are fairly snug shouldn't it be ok?
By "clean it up" you mean hit with a grinder? A lathe?
I meant steel wool to remove any high spots. Don't the roller bearings them selves ride on a steel cone that slides over the spindle? It's not like a semifloat where the rollers actually ride on the axle surface. Am I just missing something?
