PJ Walters
Registered Member
Good Morning Folks, I try not to burden ya'll too much with my questions, but I got a real pisser here that I cannot figure out. I searched all the old threads and there is A LOT of info, but I cannot seem to find anyone with my issue. Hopefully you all can help me out. I have a very soft brake pedal with crappy stopping power and before someone screams "you got air in your lines", I can assure you that after we pressure bled the system there is no air in the brake lines. The first issue is that I could lock up the rear brakes so I thought, maybe the brake lines got switched at the PV? I googled diagrams and mine was plumbed right. However, I did notice that on some MCs the 1/4 brake line is closer to the booster and the 3/16 line is in the front. Well mine was reversed and just bc I am throwing noodles at the fridge door, I changed them around. It did provide a little more stopping power and my rear brakes really lock up now (to the point that it tosses the truck sideways). However, I cannot get a definite answer if this COULD be the issue. Do some MC have the lines switched around? By all accounts, I should have a stiff brake pedal due to no vacuum, but that is just not the case. Again, we hooked up the MC reservoir to a pressurized bleeding system at my buddies garage and there is no air in the lines. All my brake lines are brand new and the rubber lines to the calipers are not expanding and giving me this issue as I clamped them off. Lastly, this is the third truck I did the disc brake conversion to. I have never had this problem and the only two things different is I have never changed the PV to disc/disc in the past and I never had a 383 stroker. This may be a dumb question, but are some disc kits made to go with a disc/drum PV? I should have jest got a hydro boost...
89 Blazer 383 stroker motor
Brand new brake booster
Brand new master cylinder (Napa M2424 1 1/8 inch bore) (I changed this twice btw)
Brand new brake lines all around
Brand new proportioning valve (switched from Disc/Drum to Disc/Disc)
Disc brakes rear (I cannot remember the kit, but they are El Dorado calipers)
