SOLD -10 Bolt Front, 12 Bolt Rear 4.56 Fresh Rebuild
fadeagray
Registered Member
Texas
Front 10 Bolt - 4.56, TruTrac, Warn Shafts & Premium Hubs, Crane Knuckles, ORD Cross Over Steering & Tie Rod, Stainless Steel Break Upgrade. All new ball joints, bearings and parts.
Rear 12Bolt - 4.56, Detriot Locker, Yukon Shafts and rebuild kit, Disc Brakes, Missouri Off Road Diff. Cover & Truss.
All new parts. Have not been used since rebuild.
Sold as a pair. $2750 Make an offer!
Dropping the price to $2,300. This is a great set of axles for 35's and trail's excluding rock crawling.
These are still for sale. I need to get make room for other projects. Make an offer.
I would be willing to ship, but would need to research options and cost.
These axles are out of a 79 Chevy 1/2 ton short box. Should fit a K5. I did modify the rear shock mount location. I have a matching upper shock mount for a K5 if you are interested. The mount was made by Missouri Off Road. Was used for mock up only.
It's a bolt in shock mount. I'll be able to take a picture on Friday.
thanks! so with this mount the installed the shocks will work with your rear axle now? otherwise the axle mounts have to be re-welded to use facotry mounts?
My goal for moving the lower shock mount was to get the shock in a protected area on the axle. With the upper crossmember you can tune shock length. This picture shows the axle and shocks mounted. This is with 4" of lift with 4" lift shocks. The frame is from a 79 Chevy 1/2 ton short bed.
Thank you for posting the pics. I have to ask a dumb question, The upper shock mount is made for pickups only? It will not work on a K-5
The shock mount fits pickups and K5's. I can scan the install instructions and send them to you if it would help explain.
