Westside K5
Registered Member
For Sale Jeep Cherokee Country, 2 door, 6 cylinder, automatic, 4x4
The transfer case is the Select-trac; Part time, Full time & 4 Low, this thing handles great in the snow and off road
165,000 miles and drives great, both on and off road.
It has 31x10.5r15 tires, retread tires (https://treadwright.com/c-7-31-10-5r15.aspx) that use a Goodyear MTR tire and then they use the same tread pattern as the MTR. These are not the old style retreads, these are awesome and I never even balanced them, they drive great. The tread is like new, they have less than 3000 miles on them!
Since it is the Country edition, it has skid plates front and rear and it did come with heavier springs, but those were replaced when I put the 3.5" lift on, with shocks.
I bought it after a girl hit a deer, so I replaced the grill, radiator and condenser. There are small dents in the hood and fender, but not bad. I also replaced the motor mounts with M.O.R.E. bombproof mounts.
Also has Flowmaster Cat Back exhaust and K&N intake system. It sounds nice, but not too loud on the inside; just enough when your on the gas, but won't drive the wife nuts when cruising down the road.
It has a nice CD radio that has a internal hard drive so you can load music right into it.
I has a class III hitch and a roof rack which works great for the kayaks.
Also included with the sale, but not installed; 1.5" front spring spacers & sway bar disconnects.
Ok, the bad: the rockers are rusted out, the paint in a few areas is flaking off, as it was touched up with a rattle can, the A/C doesn't work as I never charged it, the oil pressure gauge in the dash has never worked, so I added a mechanical gauge and the steering is a little loose feeling.
I use it as an occasional driver, go to Home Depot and take it to the sand dunes. I bought an older Blazer
, so I have to get rid of the Jeep, but to be honest, the Jeep is much better on road, and very comfortable and does everything I need it to do, I just can't have that many cars or my wife will kill me.
Call or email for questions or to take it for a test drive.
Thanks, Jeff $2450 OBO I got 2100 for it
keywords: mudder, sand, XJ, yj, wrangler, chevy, ford, chevrolet
, so I have to get rid of the Jeep, but to be honest, the Jeep is much better on road, and very comfortable and does everything I need it to do, I just can't have that many cars or my wife will kill me.Call or email for questions or to take it for a test drive.
