* SOLD *1ton axles new england area 14845 zip
sweetk30
Back to play nice .
in the back of your brain
sold the axles no longer avalible.
i have a set of 1tons 60 & 14ff srw or drw front as i have hubs for both. the rear is srw.
thay are in a 80's truck i am building up for play. i have a spare set of axles i am building and when ready i am just going to swap springs/axles all as 1 unit.
thay will prob need a little going threw as been sitting for 2-3 years . but other than thay direct pull outs.
i will even have a set of 56" rear springs i can include also or sell seperate.
all items will be local pick up or possible meet & great part way for gas & time money.
looking for 900 for 60 srw and 14ff srw rear.
looking for 750 for 60 drw and 14ff srw rear.
and 150 for the pair of springs.
yap . still have . front is out and rear can be out in 20 min. full shop at my use to remove.
everything you should need to swap in and spring plates for both axles.
Perfect!
I'm all over the 60 srw and 14ff srw rear.
I just need to find a ride so i can come pick them up. Should be able to this weekend.
well let me know a few days ahead of time. i need to dig out the truck and also get it to the shop and have my other axle ready to swap in to keep it a rolling truck.
I'm looking at converting my SRW K3500 to DRW. I'd be interested in those DRW front hubs if not spoken for. Cash or trade of some sort for a SRW set that has new calipers and rotors.
A DRW 4.10 14 bolt would be a sweet kicker if you have one floating around.
Basically i am looking to trade out SRW Dana 60 front hubs that have new calipers, rotors, and pads and a 14 bolt FF (3/4ton spring perches) 4.10 gears gov loc. w/recent brakes and new drums for DRW 60 front hubs, new rotors and calipers would be nice, and a DRW 14 FF with 4.10 gears. New brakes and good drums would be a plus.
I haven't officially posted it yet but I'm sure someone will jump on it when the time comes.
and as always like others have stated money talks and first come first served or i would have posted up possible sale and waiting for payment. i do have emails of others that said if others have it first sell it dont wait for me.
i have 2 sets of drw hub/rotors in stock . so dont pull out any hair about that. i will work you a deal on your srw stuff.
and i will keep a eye open for a 3/4 ton rear in good shape.
I'm looking for a 1 ton perched 14 bolt DRW. I have the 3/4 ton perched 14FF with the 4.10's and gov-lok. I would trade it straight for what I am looking for in good shape.
I want the narrow C&C. I have a full width D70 I could trade as well but I don't know the ratio. It was a 454 2wd so probably 3.73.
My truck is an '86 K3500 SRW. It's currently on a 3/4ton frame due to NE salt. I picked up a nice CUCV frame and have been setting it up with a cummins NV4500 NP205 combo. Plan is to swap the K3500 body onto the re-powered frame... and I want make it a dually at the same time. So, as we speak the truck has D60 SRW under it and a 3/4 ton 14FF. I would like to make that into a C&C width DRW. Simple soultion seems to be swap hubs on the front and trade the 3/4ton 14FF for a 1 ton 14FF because it's not worth the time moving the backing plate and perch mounts. I think most peple ditch the dually stuff for SRW stuff so there should be an adundance??
i think i might have a good bare housing for ya let me check. then all you would need to do is swap gears and bolt up and go.
I guess that would work as long as it had the hubs, backing plates, drums etc. I wouldn't want to put too much time into it becuase they can be found in decent shape on the cheap.
