*sold* 4.10 gears, two sets, 10-bolt and 14b s/f
Blue85
Yooper
Keweenaw
I'm swapping out my 4.10s. The 9.5" set is out. I will post up on the 8.5" set once they are out.
This gear set had some rust pitting when I swapped the axle in several years ago. I never had any problems with it and it looks the same today as it did when I first saw it. All of the bearings and everything were in great shape when I tore it apart last night. The pictures show the worst of it. I believe it is an OEM set. I'm thinking this is worth $50 since a new set is about $200.
8.5" carrier is out and the gears look awesome. It is a Yukon set. Miles are low because they were in the front. I would like $70 for this. Shipping weight should be around 20lbs.
UPS is quoting like $28. I wonder if this would fit in a flat rate box?
EDIT - The biggest flat rate box is only $14 and it might even fit in a smaller one. Gotta love USPS flat rate.
The 8.5" set is packed in a medium flat rate box, so it ships to you for $10.70.
I might be able to get the 9.5" set in the large flat rate, which ships for $14.50.
Make an offer?
Not really sure why i missed these. Any action on them? If not, PM me, i need both front and rear, we'll work out a deal.
Listed on eBay and sold for more than I asked here. Who knew.
