SOLD 8-lug chevy dana 44 4.10 placerville SOLD
rydawg
Registered Member
Sierra Foothills, CA
SOLD
8-lug chevy dana 44, 4.10 gears, open, complete. Got this axle about 5 years ago, at that time replaced the ball joints, wheel bearings, tie rod ends, rotors and calipers also added a milled/ drilled/ tapped passenger side flat-top knuckle. A few thousand miles and one Rubicon run, and the K5 began going through major surgery. This axle has been sitting in my yard now for the past 3 years.
The passenger flat-top knuckle is older and the TRE is tapered from top to bottom, and the driver side one is bottom to top, so the tire rod sits at a slight angle but I don't think this affects anything. Won't matter anyway if you go to hi-steer.
$300.
What year is the axle out of. Would you be willing to part out the hubs, spindles, and lockouts? Would you be willing to met me in Fresno bakersfield area
I believe this came out of an 82 or 84 3/4 ton suburban, I bought it from Willyswanter about 5 years ago. I don't want to part it out. I'd be willing to meet in Fresno if you help out with the gas.
I am still interested in the axle and would get it whole. Is the ring and pinion good with no chips out of the teeth etc and seals and bearings in the axle and hubs fine/good? I may have to wait several weeks to get it but will let you know.
Hoby
