*Sold* '87 K5 Blazer. $1000 in Williamsburg, VA
deadlew
Williamsburg, VA
Selling my 1987 K5 Blazer. Here are the specs.
-Motor
'78 4 bolt main block and heads. Using the TBI injections.
Edelbrock TBI cam, Eagle crank and rods, hyper pistons, double roller timing chain w/torrington bearing, heads rebuilt. Poly motor mounts. 9.25 compression ratio.
-Stock 700r4 tranny.
-NP 205 tranfercase twin sticked, 32 spline front output.
-Ford 9" rear axle, 6 on 5.5 bolt pattern, spare axle shaft. 3.50 gears and trac loc.
-10 Bolt front, 3.42 gears with trac loc. New wheel bearings, ball joints. Spare axle shafts.
-2.5 suspension lift springs front, ORD shackle flip rear, cross over and high steering, ORD steering box frame brace.
-H.A.D. 1350 CV rear drive shaft, and rebuilt front drive shaft.
-35x12.50 BFG ATs.
-CUCV grill guard and tow points.
The body has rust in the rockers, in the floor near the tail gate. Also has a ORD engine cross member but not installed. Have the pedal assembly and all clutch linkage parts and brackets to convert to manual. Included is a set of (4) original 15 x 7 alum. wheels and center caps.
*Added July 28th. Also will throw in an SM465 tranny, new SM465 10 spline output shaft, bell housing, SM465/NP205 adapter and the 10 spline input shaft for the NP 205.
$1000 o.b.o. E-mail for pics and phone number. Located in Williamsburg, VA.
PaulC
