Sold delete...Snorkel...
mr250twostroke
Eatonville, Wa
be ready for the sea of oil when it hits your streets, you can thank me later.
pre bent, no disforming on the outside (took my time) and fits nicely.
$210 shipped... all parts as recieved.
How's that connect to the air cleaner housing? Have any pictures of that? Is everything included as far as hardware, A-pillar bracket and air cleaner connection stuff? Have a picture of the hole in the fender and would you be able to create a template for cutting the hole? Thanks.
You will have to get a sealed (or make like I did) aircleaner and hose to attach. Id take a pic of mine but sold that already to a mud bogger who did an in-cab filter. Everything else is including as shipped from ARB. I had to modify the pillar bracket since it was originally intended for an fj80. I'll snap a pic of the fender and would also make a template for the buyer, the orignal template wasn't spot on for our trucks.
Thanks for looking, should have a pic up by lunch "our" time.
Had to cut the pillar bracket down, its plenty strong/firm.
Here's the hose coupler/clamps and and nut/washers...
Had to hog out the holes to the left because the original template wasn't exact on my fender. I will make a new one that fits our trucks....
You would need to make a u-cut in the upper corner where the red cable goes thru the grommet to access the rear studs. Just fold it up, then back down once attached...
You'll need to relocate your rad overflow if located here...
And run a hose over to your sealed aircleaner
Hope that answers everything and thanks again for looking!
Still got that snorkel? I'm interested. Also, you did a great job mounting it and it looked good, so why did you take it off?
Yes I still have it. Took it off cause I like to take my burb places I shouldn't, things are tight out here in a blazer let alone a suburban.
Thanks :D
I sent you a PM. I actually don't get off on crossing deep water anymore (I sank my '77 GMC in a river) but I want a cold air intake and plus they look freakin' sweet.:D
Been camping all weekend but hillbilly deluxe was 1st thru pm's. Thank you for your interest for those that responded as well.
