Sold, mods delete me plox tangoo veddy mudge
No, the Strawberry Crush is not included. I put it there for scale as I had no Coke cans handy =))
-- A
I'm half tempted. Do you know what the rating is on that 6' strap?
Says "Webbing sling 4 ton" on it, though I've always associated "sling" with overhead load as opposed to the horizontal stuff we do so it might be rated for more for pulling. :dunno:
-- A
Straight pull is from loop to loop, if you wrap that around a tree and hook through both loops you just doubled the rating...
Rene
Make a decent tree saver then ... but I'd not use it to go yanking a rig stuck up to its axles in mud. (Though how you'd do that with a 6' strap :dunno: anyway :D )
-- A
Lifting equipment is allways rated 4 times less than the breaking strength. If you have a 1000 lbs rated lifting strap it has a 4000 lbs breaking strenth. Towing is rated at half the breaking strength. 2000 lbs = a 4000 lbs break. I've used 4 in. endless straps to pick up 6500 lbs alxes from heavy equipment.
