This would be the top half of a full-vert windshield header from a '74 Blazer. You would cut the roof off your '76-up Blazer and weld this in place to make it full convertible. I seem to recall that I found so 3/4" or some tube that fit inside the pillars nicely to keep it all aligned.
Includes the three brackets to bolt onto a hard top if so desired.
No catastrophic rust -- it's from a CA truck -- but does have a lot of holes from the snaps for previous soft tops. Depending on your plans you might need to weld them up.
Easier if you pick up, of course, but if you're not near the middle of CA where I am, I can ship it to you on your nickel. PM me with your ZIP and I'll get an estimate. While I think it can go ground, the sheer size will make it not cheap.
Call it $50 plus the ride.
-- A
-- A
