Have here a setup from TSM Manufacturing that adds a mechanical caliper as a parking brake, using a dual caliper bracket. It's totally separate from the hydraulic, so you can use regular cheapo calipers, not the Caddy ones. It works well once you've got it adjusted. I ended up going with a transfer case parking brake on my rarely-moves, so while it's been installed it's only been driven a few miles.
Here's the dual caliper bracket:
And then with the mechanical caliper (red) and the regular caliper (blue):
And what it looks like assembled off the truck:
The brackets are flat and use the spacers to align with the rotors. All hardware is included and is grade 8 and the parts are all powdercoated, though there's the odd scratch and such from installation. I'll also include the cables and their brackets which worked on my '74. If you have a newer rig, you may need to make a new cable from the adjuster to the junctions for these. You can get these made or DIY with cable and ends from the hardware store.
I'd like to get $350 for the set, shipped to your door.
Now, before you scream, note that TSM is very proud of their parts, and new this setup costs about twice that.
To their credit the parts are really nicely made. Plus, if you don't want to mess with the Caddy calipers, this will allow you to pass inspection in those locations require it, not wear out your parking pawl, etc.
Should you happen to need them, I also have a set of appropriate hydraulic calipers which I can include for cheap. You'd need a set of soft brake hoses (search here for part #'s, think from a Chevette), and this package would give you an almost-entirely-bolt-on 14BFF rear disc setup with parking brake.
Instructions for the calipers can be had here; the bracket works like any other disc conversion.
PM me with questions or whatever since I don't always read the threads.
-- A
To their credit the parts are really nicely made. Plus, if you don't want to mess with the Caddy calipers, this will allow you to pass inspection in those locations require it, not wear out your parking pawl, etc.Should you happen to need them, I also have a set of appropriate hydraulic calipers which I can include for cheap. You'd need a set of soft brake hoses (search here for part #'s, think from a Chevette), and this package would give you an almost-entirely-bolt-on 14BFF rear disc setup with parking brake.
-- A
