Specifically, Explorer ProComp #7220:
http://www.summitracing.com/parts/exp-7220
These are for '79-'87 ('91) trucks, i.e. any 1/2 or 3/4 ton whose calipers have the 10mm banjo bolt. (The rear is the same for '73-up.)
They would not fit the '73-'78 fronts with inch banjo bolts.
The front lines are used, and the blocks have been slightly clearanced to fit into the calipers with a ring around the fitting. (They have plenty of metal on there and I just rounded the corners.)
The rear line is brand new. Long story.
The fronts are ~28" long and the rear is ~21".
Since they're half used, how about half price? Call it $50 to your door via USPS Priority Mail. PayPal preferred.
Note that I sometimes sneak extra stuff into Flat Rate boxes (doesn't cost any more if it's heavier) so if you don't like your free gift, you have tofoist it off begrudgingly give it to the next sucker lucky recipient.
Also note I don't check the threads often, so if you're interested, PM or email me.
-- A
The fronts are ~28" long and the rear is ~21".Since they're half used, how about half price? Call it $50 to your door via USPS Priority Mail. PayPal preferred.
-- A
