TruckNutzDude
UPDATE 11/24/08
Everything has gone to AYCHDEE
UPDATE 11/22/08
***Sale/Trade Pending for Sunday 11/23/08***
'78 chevy shortbed parts truck. 350/465/205 12 bolt rear 10 bolt front. Extra front shafts. 31" bfg all terrains on stock steel rims, 3" body lift, 2" suspension lift. The body is junk, the bed has no floor and is currently not on the truck. The cab has no floors or rocker panels and is rusted up to the lower door hinge (the hinge fell off!) I bought this truck for parts, the frame/drivetrain and some '78 specific parts are all that I'm selling.
It has the TACH IN the DASH!!! $400 with a CLEAN TITLE!
6" BDS front lift springs, new, installed but never driven on. $200
SM465 with 205 case, excellent condition, trans was rebuilt with x-member from '79 K5 $200
Std trans column from '87 K5 $50
Std trans column from '79 K5 $50
Hedman headers for 350 in '89 K5, ball flange, 1 year old $50
2wd box NOT tapped for hydro assist $50
Winch mount for '89 K5 chassis, accepts WARN and MM winches, also others. Made from solid 1/4" plate. $40
MM12,000 pound winch w/ roller fairlead $300
Power doors from '89 K5, good condition $40 pair
York air compressor, v-groove pulley $100
Door glass, vent glass, sliding k5 windows, misc. tail lights, marker lights, switches, etc from various years and models of K5 and K10 trucks. offers?
4- 44x18.5-16.5 TSL's on 12 bolt H1 beadlocks with the light-weight inserts from USA6x6 $1,500 (no shipping please)
Chevy D60, diff guard, 1350 spicer u-joint yoke, 5.13 gears, strange spool, 35 spline non-neck inners, 35 spline spicer outers, spicer non greasable ujoints, ORD x-over arm with drag link and pitman arm and 2"x8" stroke hydraulic ram, *needs one hub (went with milemarkers and blew one right away!!!) Also comes with ORD shackles, greasable bolts, 52" chevy springs, zero rates and the brackets off my truck. $1,500 FIRM (no shipping please)
14 Bolt full float, diff guard, 5,13's, welded (mini spool style), DIY4x disc bracket with 1/2 ton calipers, new rotors and pads. Comes with 64" springs, Belltech shackles and the brackets off my truck. $650 FIRM (no shipping please)
I also have 4x 12" travel Doesch Tech shocks and 2x Ford Superduty shock towers. $150
UPDATE 11/22/08
