PsRumors
Sold...what a sad sad day.
If it doesn't sell within the next week I will start parting it out. If you want higher resolution of a part let me know. The videos are a little on the small side but otherwise they would have been too large to easily download.
This is really to nice to part but I need it gone. Over $17k invested.
Quick overview, '84 k20 Suburban, 454, Bowtie Overdrive 4l80e, NP205, Dana 60, 14bff, 4:10 gears. All ORD suspension with greaseable bushings. A detailed list is below.
Asking $7000 shipped within the Continental US.
Rebuilt 454, stock spec - $2600
Edelbrock Intake & Carb - $622
Bowtie Overdrives 4l80e & Compushift Controller - $3720
Advance Adapters 4l80e to K Bolt Pattern Np205 - $341
Rebuilt NP205 fixed 1310 outputs - $705
Dana 60 30 spline 4:10 Gears New Rotors, Calipers, Pads, Warn Prem - $1640
14 bolt FF 4:10 Gears - $445
14 bolt Mag-Hytec Cover - $255
14 bolt Disc Brakes - $300
Front & Rear Driveshafts - $740
Off Road Design - $1350
Tough Country HD Springs
Front Shackles
Front Upper Shackle Hanger
Front Greasable Bushings
Front U-bolt Kit
Rear Shackle Flip Kit
Rear Greasable Bushings
Rear U-bolt Flip
Steering Brace
4.5" Super Shackle
1/2" Zero Rates
Sway Bar Disconnect (not installed)
Rancho RS9000XL - $480
Discount Tire BFG 285/75/16E AT - $900
American Eagle 186 16x8 - $435
NOS Dash Pad (not installed) - $345
$14878
+ $2300 in exhaust, door hinges, spring perches to set the pinion angle without shims, cross member, radiator, hoses, new A/C hose, battery, brake lines etc.
Total $17,178
http://s291.photobucket.com/albums/ll281/psrumors/Burb/?action=view¤t=BodyOverviewSmall.flv
http://s291.photobucket.com/albums/ll281/psrumors/Burb/?action=view¤t=Interior.flv
http://s291.photobucket.com/albums/ll281/psrumors/Burb/?action=view¤t=Undercarriagefinal.flv
http://s291.photobucket.com/albums/ll281/psrumors/Burb/?action=view¤t=Running.flv
The only bad part of the burb is the paint, the brake pedal is weak (I think it needs a MC) and the rear seal on the intake is leaking. When I installed the intake I pushed the rear seal right off the block. It can be seen from the underside.
This could be a awesome tow rig with just a little bit of work. I am just bored and need the money for other projects.
Front Shackles
Front U-bolt Kit
Rear U-bolt Flip
Steering Brace
4.5" Super Shackle
1/2" Zero Rates
$14878
Total $17,178
