Sold
JeffHK5
Cincinnati
I have another good working Chelsea PTO off a Sm465 for sale ... comes with almost new engagement cable and good drive shaft.
This unit has a rear facing output ... came off wrecker and ran a 15K hyd. winch.
$100 plus shipping
..I have the reservoir/pump unit but it's not part of this sale....the winch motor was sold earlier.
The problem is the tank/pump is very heavy (70+ lbs.) and is super grease & oily and would be a pain to ship.
Jeff
It'd ship fine on a pallet through Forward Air, they just want it wrapped in plastic or cardboard... and not leaking/dripping. If you are interested in selling it shoot me an email and pics. I might be in a position to buy it next month.
New price......
$75 plus shipping.... I'm not interested in selling the res/pump unless you live close enough to come pick it up....
then I'll take $125 for the whole deal.
PTO's are specific to transmission and T-case...so this only works on a SM 465.. I copied this from a PTO discussion as it's good info.
________________________
The pto for a 205 is different then the pto for a 465.
The 465 pto spins in 1 direction only. I have heard there are mutable direction 465 ptos but I have yet to see one.
A pto 465 or 205 IS asymmetric you can take it a part and change what direction it is pointing. On the 205 good luck getting the speed o cable to fit if you have it pointing out the rear."ask me how I know"
VERY IMPORTANT THING TO REMEMBER the 465 pto idler gear is a constant mesh gear you MUST have some back lash between the gears this accomplished by stacking gaskets if you don't do this and just silicone it on bad things will happen.
Also the 205 pto runs of the idler gear in the t case and speed and direction is set by the trans. T case can be in N and pto still works.
