Sold
JeffHK5
Cincinnati
New Comp Cams cam and lifter kit. Brand new, won't work for the motor I have. Cam has been opened and pulled from the bag, lubed, and set in place, but never run. Pulled out immediately and re-bagged. All other parts are untouched.
Kit is #K11-238-3 from Comp Cams. Kit includes Camshaft, Lifters, Timing Chain & Gears, Valve Springs, Spring Retainers, Spring Locks and Valve Seals. Runs $340 from Jegs or Summit.
For 396-454 BB Chevy engines
Advertised Specs are:
Lift: .504''/.510''
Duration: 262°/270°
RPM Range: 1300-5600
CAM KIT IS SOLD !!!!!!!!!!!!!!!
Also have set of Comp Cams 1.72 ratio Magnum roller rocker for a BBC.. these have maybe a thousand miles on them.. they come with pivot balls and nuts. $140 from Jegs or Summit.
I'll take $400 for both the cam kit and rockers , shipped anywhere in the lower 48 ....or all 50 for a little more. I'm in Cincinnati so if you'd like to pick up we can negotiate on price.
Pictures are available if your interested.
Thanks, Jeff
Edit: Sorry for the damn yellow text...can't seem to change it.
wow yellow again ? ? ? ?
comp cam kit is this yellow ?
checked edited nope mines not yellow. got to be on your end. you not by chance copying and pasting from other site are you ? possible conflict ?
I wrote this add originally and posted on a local page.. pasted it here and PBB...yellow both times:confused:
Hell , I even tried to fix it by deleting all the yellow text and retyping it ... no luck.
It also did ORD and AGR on my other post??
Kind of hard to read the yellow on a white background.
A little trick I always use to get rid of funky format code, simply copy your text and paste into notepad, then recopy and paste back into where you want it, notepad will strip it out for you.
Thanks for fixing that ..:bow:
I think I know what I did wrong ... I copied this from a post I found through the "search" function on my local board... yellow text where the ones I used as "target" for my search.
Jeff
I've had several people ask for pictures of this stuff.... not much to look at.
Everything but the cam and lifters are in unopened packaging ... tappets never left the box and the cam was taken out of the plastic bag , lubed and put back in the bag.
Rockers have one year of very limited driving ... then where removed when I sold the 454.
If your a serious buyer and need a closeup of the cam I.D markings I can get that.. it's currently covered in Redline prep lube and messy as hell.
would you sell the rocker arms by themselves? if so, how much do you want for just the rocker arms shipped to 72143...thanks
Need 2- 1410 yokes for D60/70 diffs.
Need some GenIII (LS-LQ) stuff..steering pump..or performance parts
Propane stuff for V8
If you or anybody has trade material I'd be willing to add $$ for the right deal.
I'm open to offers.
