sold
K85 Octane
People Fatigued
San Bernardino CA
I have two. One pulled from a local J-yard here in So Cal and another I bought as a back up plan if I couldn't get one local. It's from some other state I don't remember. The black one is from here. I pulled it apart, drill a couple holes and welded a couple nuts in place. There are a couple set screws there too.
The other one is untouched. It has surface rust all over it, but since I don't need any shafts anymore, I didn't bother sanding it off.
both have good joints. The black one needs a quick tap ran through the top nut. I don't have taps. I have the plastic spacers for the black one, they aren't on it, but I'll include them. For some reason I had a hard time sliding the male end back in with the spacers, so I gave up on it to work on my truck.
$40 - black one SOLD
$30 - rusty one
shipped
obo
thanks
I work in Downtown LA. Live just outside in Temple City.
I did the nuts and set screws to be able to tighten down any remaining slack between the two shafts. Though with the spacers in, there isn't any. I put my other one on and tightened them down a little, but not so much as to hold the shaft from sliding if need be.
I'll drop $10 off if anyone wants to pick them up.
it needs to be pulled apart, just heat the connection and pull apart, standard procedure :) Or you can measure your old shaft (~21.5") and using a hammer or some kind of compression method, compress the xj shaft to that length once it's heated. Let cool and ur done.
the black one is sold
Dude Really!!!! I called you brian like 20 times yesterday, should have corrected me. Sorry about that.
...and you better believe Ill be back, Ive always loved that area. People not from socal have no idea what theyre missing in dowtowns fashion district.
I'll take the other one. PM me and let me know if you prefer PayPal or USPS money order, as well as where to send the money to.
On the off chance you'll be near the I-15 corridor either tomorrow afternoon or Sunday afternoon I'm going to/from San Diego this weekend and could meet you.
