sold
MNorby
3/4 ton status
Powell, Wy
Had this leftover from all my OBA stuff. Pretty sure it went right onto a york or similar but don't have one anymore to verify. It's off a semi truck air compressor application designed for high heat. It is 54" long. $25 shipped.
Can you package that with the comp switch in the other post? how much for both shipped?
have any York mounting brackets?
I do have a york bracket I made years ago for the 454 but the pivot pointed needed to be moved since it tensioned at same angle as belt almost. Can see if mounted here. I can take some pics of the bracket later this week if you would like.
I'm running a serp setup, and mine is on the pass upper location, so I'm guessing I will be looking elsewhere for those, or making some!
How bout the hose and switch?
I'll post up some pics next time I get to the shed, might be able to modify it easy enough.
How's $35 shipped for the switch and hose, just for you?
works...PM me with paypal addy?
