Sold
Any interest in separating? I could be interested in the 14FF.
Ill consider it if they don't sell as a set. I may have another set coming available. If I do, I will for sure separate them and let you know. I do have a 14 bolt with 4.56 gears and detroit, BUT the detroit is messing up. I need to pull it apart to see what is wrong..
If you're already pulling the other apart... I have a detroit. I really just need the ring, pinion, and carrier. Let me know.
Fair enough. Let me get it pulled apart and make sure nothing else is messed up. it will be a day or two, but I will get back to you.
I was looking complete 14 BFF with DL (listed it a while back in the wanted section) but didn't think you wanted to separate. I already have one but it is open.
I don't want to separate at this time, but if I had another set available or someone wanting the 60 I would. or, if they just are not moving. I check the wanted section occasionally but if i don't have it at the time, I don't generally pay attention.
Moved the axle around to the shop. Popped the cover..gears are good from what I can see. I will pull it the rest of the way apart tomorrow to make sure the carrier is good and the gears are for sure good. .
