Sold sold
Interesting piece. Reason for selling? Will it work with crossover/high steer? I can't see too well on phone, but I am getting ready to put tons under a 90 Sub and this may be a good upgrade. Also, planning on 4" lift if that matters. Thanks.
John
John
Came off a rig i parted out. Will probably work for crossover w/ high steer but i can't guarantee unless you run the tie rod in front of the draglink or run a reverse high steer setup from WFO or similar that puts the tie rod behind the axle. I and a couple others on here have the reverse high steer if you aren't familiar with it. It's pretty cool because it completely protects your tie rod while also eliminating all the congestion up front. Worth checking out if you haven't already bought traditional high steer arms.
Also, something i need to note. Those u bolts in the pics are actually for the driver side spring plate. I need to check my shed again to see where the correct u bolts are for the panhard tower. They are much shorter.
