GRINCH
I'm not a rookie when it comes to soldering but occasionally have problems.
Last night I was trying splice two wires together. One end was some factory 10Ga wire from a Ford Windstar fan and the other was some new 10Ga stranded wire.
I stripped the wires back, added some flux and tried heating up the connection using my pen type soldering gun. It just wouldn't get hot enough to melt the solder through the wire. I just soldered some 12Ga with no problem.
Frustrated I took out my OXY/ACY torch and put on a small tip and heated it up really good and still could not get the solder to flow.
I did manage to hack solder it, but not happy with the job.
I am also using some of the older style "real" lead solder.
Any ideas what could be the issue?
I did manage to hack solder it, but not happy with the job.I am also using some of the older style "real" lead solder.
