I removed one of my doors, adjusted the hinge on the cab, and re-hung it. I got lucky and only had to do this once to make the door line up. There is a hinge bolt hidden under the dash that you have to loosen. The adjustment at the door will move the door in or out to the cab. The adjustment at the body will move the door up or down at the striker side. Use the body lines/curves to judge which way the door needs to be moved. I have never had a set of fenders off, so I didn't want to go to all of that work just to adjust a door. I also had one door that was rusted and split right next to the hinge. This was on the passengers door so maybe the hinge was too stiff and went unnoticed. I replaced that one, before my truck was painted, with a junk yard door. You can also tweak the door body slightly by pulling on it. The top of my door seemed out of alignment. My dad used his hands and body to twist the door slightly and it fixed it. I was sure it would mess up the door but was proven wrong. Just be careful if you try that.
