Well, sorta ... but we talked about that. One-tons have hydroboost, which, yep, is a great thing ... but means swapping your power steering pump, booster, master, brake pedal, and assorted plumbing. BTDT
My experience with vacuum boosters, which admittedly is for the 73-80 trucks, says that they're all basically the same.
My experience with brake systems says that changing parts piecemeal to something other than stock
will come back to bite you in the ass. Either swap the whole thing to hydroboost, or replace stock parts with stock parts... changing anything can make it worse and makes it hard to diagnose what's wrong.
I don't mean to be a hardnose or rude here, but I have had some experience in this arena (including "upgrades" making an otherwise perfectly good truck completely undriveable
) and so I feel compelled to share.
On my K5 I still have a stock-type master and vacuum booster, the stock combo valve, and discs front and back. (Fronts are 3/4 calipers and rears are Caddy Eldos.) That thing will stop when I bang on the pedal, like push you out of your seat. (If the Doubler is in 4:1, she'll try and creep unless I push the pedal hard, but hey, that's a LOT of torque, ya know?)
Point being it WORKS, so I shouldn't mess with it.
On my sixpack I have hydroboost with a stock-type master, no combo valve, adjustable prop valve, and discs on all four corners (one-ton Bendixes up front on and Eldos in back again, but on weird rotors as it's a dually.) This one will fling you through the windshield if I bang on the brakes hard enough.
But, it was a PITA getting it to that point, and it took me MONTHS, seriously, of the truck not being safe to move out of the driveway (as in totally flat pedal, leaking brake fluid, etc etc etc) to get it there.
It *was* working and I "improved" it, Tim Taylor style, and took me FOREVER to get it *really* working again. If I hadn't torn it apart, I'd have put the stock combo valve back in by now.
Your mileage may vary, professional test driver only (do not try at home), void where prohibited, allow six to eight weeks for delivery, printed on 100%
recycled electrons, etc.
-- A
