Your shock mounts are in a very vulnerable position!!!
beater_k20 said:IIRC that's a line from Talladega Nights, not Zen.![]()
I think he meant with the 14bolt shocks in the stock location on the rear axle. Most people try to move them to the top of the axle. One rock comes through and that rear shock is going to get banged up.olskool said:Well I know it was said that I had a bad shock angle, but it's still holding and doing fine.
justhorsinaround said:No flaming here. Nice looking truck!
. Whats with the oregon plates ?? I have a drill press and some good bits so it's not to bad to drill through springs (lot's of cutting oil) but I would worry that the springs would crack and snap at the old hole location
. Looks like you will cutting off lot's of sheetmetal if you are going to run larger tires .
