some pics and what does this stuff do
84CUCV
3/4 ton status
NJ for now
its a 80 350. would like to know what this stuff does. i sure dont know. :crazy: thanks
thats a 205 with the wire out the top. not even a place for it to plug in thanks
1 - relay for something
2 - coolant sender
3 - tcase 4x4 indicator idiot light on dash ?
4 - another relay for something
5 - common for people to use a dead sender to plug that hole in the other head
#1 and 4 are a relay. No idea what for.
#2 and 5 are temperature senders. #2 is factory for the gauge; #5 is prolly aftermarket, unless it's for the computer or carb or something.
Tcase wire could be 4WD indicator, or could be digital speedometer, if it was transplanted from a 90-91. Check the tag to be sure. (I know the 208's for 90-91 have VSS for the DRAC; I don't know if there were '205's and if so, if they had it.)
-- A
those relays good have been added if someone removed fuseable links..just a guess though
edit:
wait nverermind that makes no sence if you look at the wiring
I just did a swap of a 350 from a 76 into an 86. There was lots of crap like this left over. Thank God, all you really need is 12volts to the coil.
Horn relays, sender for gauge, tcase is for the light on the dash.
