So I recently got a 95 k3500 from my uncle, its got the 6.5 TD with only 88k on the clock. He bought it from a friend of his' elderly father. It runs great and drives great but sometimes it has an attitude when you go to start it. So I guess ill start the story here, the day after my uncle got it, he went out to drive it and it wouldnt start, so he ordered a new pmd, the new style that mounts to the top of the intake, I put it on for him. Then he took it to his mechanic and had him go through it and replace what needed replacing. Im not excatly sure all that he did but I know he put 2 new batteries in it, changed the belt, I think he may have done fuel filters as well. So about a month later I got it from him and Ive been letting it share DD duties with my 72, here are the issues I am having.
If it sits for several days, I go to start it and it cranks right up, runs for 30 seconds or so and then dies, then I have to crank, crank, crank and it will fire up and run good. Sometimes, on hot starts, it will not want to start and take alot of cranking to get it to run. And lastly, usually almost every cold start after sitting overnight it will crank up and stay running but its like it is cutting in and out on me, it runs jerky for like the 1st minute that its running. And one last thing. The fuel gauge doesnt work, usually it stays pegged out past the full mark, but sometimes it will go down to F or to 3/4 tank at random. Would you guys be checking the sending unit ground or replacing the sending unit. Or is it possibly the gauge? Sorry for the newb questions but this is only my second diesel vehicle, used to have a 6.2 jimmy but sold it because I never could get it running. Just trying to see if I need to start replacing some parts that might be causing these problems. Thanks guys.
