Nutro
I'm unscrewing everything the previous owner screwed on this 88 K5 I just bought. They removed all of the smog stuff and removed the cruise control under the hood. None of the A/C or heater stuff was working. I found the blower motor resistor was dead. Installed a new one and I have air movement now. Under the hood, The vaccum ball has 2-3 feet of rubber hose and into a Tee. That's it. As I understand it, the ball only holds vacuum for the cruise setup.
Out of the firewall, the little brittle 1/8" vacuum hard line was taped off. I removed the tape and need to figure out where I can get vacuum so that the Vent/Defrost etc works. As it is now, I can get air movement but the blend door isn't switching functions.
I also noticed on the rear of the intake behind the Throttle Body there is a Tee or vacuum fitting. It looks like someone plugged it off. Can I just run that main 1/8 hard line to that manifold vaccum?
With them removing the smog/emissions/cruise control stuff, I am LOST on what should go where etc
