heres what i had on my mind
Actually you will be bigger than quagmire, he was only running 38s in the front
yes that is correct, but he had bigger than 54's on the rear, iirc
this is/was the plan ...set the truck up with the 12'' lift and 44's all the way around, rear is 8'' springs/4''blocks....not sure of the gear'n yet haven't popped a diff cover off to see, what ever was stock in a 86 k30, prolly what i will run until it breaks....i have a sm465 trans so i can get the gearing pretty low w/4.56's(granny is 6.12:1..iirc, t/c is 1.96:1, rear diff 4.56:1=54.7 final crawl,4.11's=49.3?) in mud
really steep gears are not all that necessary and 50-54:1 would be plenty low, i believe..
i use the truck w/ 44's as my toy..i.e. trails, mud, gravel rd, camp grounds..
but once a month when they have the mud pit open for competition, i would have another axle, set up with just 8'' springs and 54'' boggers(no blocks),.. geared to match the front w/ tire difference. 2-3 days before the event, just swap out the rear, springs and all...6 bolts. 2 shackles and 2 leaf eyes, and 2 shocks...i am going to go by an industrial supply and see if i can't find a way to put a quick dico in the brakeline. go run the pit, then swap the springs back out to driveable 44's all around.
since this is just a toy, it would only be in 4x w/54''s, in the pit and i doubt very seriously it would ever see 65 mph, 45 would be fine. so, now that you know what i'm thinking...tell me what am i forgetting?
edit: emergency brakes on axle w/44's will be disk w/eldo calipers(unhook the cables) or a line lock for emergency brake, 54'' axle, don't need no stinking brakes!
